I have been using my Sony Experie M2 to play music through but have noticed recently that when I put the phone in my pocket the music stops after a minute or so and if I remove the phone to reactivate it, the music starts again.
The same happens on different music apps which seems to me that it might be a phone settings issue. It is probably something quite simple that I need to do but I cant seem to work out what I am doing wrong.
Any advice is appreciated
I've tested my sons M2 but it all works fine, I'm inclined to think that performing a system repair may fix it as a bad upgrade could be the culprit but I can't be 100% sure
Do you have Stamina mode enabled?
Thanks for your reply. I thought it might have been one of the powersave options and put them all off including stamina but it hasn't made any difference.
