You mean you lost your phone and you want to block it? If so you have 2 option, provided that you enabled one of them at least:
- Go to Android Device Manager and choose your device, you have the option to LOCK, ERASE, or RING on it.
- Go to MyXperia and do the same.
Also contact your network provider who can block your Sim card
Thanks to everyone for their support.
