Hello,u just update my sony xperia m2 d2303 yesterday for android version 4.4.4.i noticed that the notes app and some widget are lost..can somebody please help me how to recover these things bcause i hv many important things inside the note..thank you
Add me to the list - so frustrated. Do we think Sony will provide a solution?
Batrisyia, please, where can we download the Notes application? Thanks.
don't know what to do anymore
I'm very sorry to hear this. I will forward this internally to see if there's any way to retore the app or recover the notes.
@Macarronen wrote:In the first entry ot the thread now says: "Solved! Go to Solution. ". Clicking on the link jumps to the fourth entry:
"There isn't much to say here, you could sideload the app, what I will suggest is to whenever you get access to your notes download Google Keep, that way you don't have to worry about losing them ".
Solved? Can anybody tell me where is the solution to this problem?
There isn't any solution. Only solution is to start over with another memo/note app that actually saves the notes somewhere safe.
