Bonjou, j'ai un gros problème. L'écran de mon Sony Xperia M4 aqua ne s'allume plus. Aucun moyen de régler le problème, j'ai suivi pleins de conseils sur internet comme forcer le redémarage du téléphone mais rien n'y fait ! Merci de votre aide par avance, je suis étudiant et je n'ai pas vraiment les moyens de me repayer un téléphone...
Bonjou, I have a big problem. The screen of my Sony Xperia M4 aqua no longer lights up. No way to solve the problem, I followed many tips on the internet like force restart the phone but nothing works! Thank you for your help in advance, I am a student and I can not really afford a phone ...
gt
Hi @Armac , I'm really sorry to hear about that.
It's really hard to say what's happened here. But if it does not work to force restart the phone it does not sound like it is related to the software.
In your case i would recommend you to contact your local support team for more information about how to send your phone in to an authorized service center.
Let me know if you have any further questions.
