Jak zablokowac konkretny niechciamy numer ?
How do you block a specific unwanted number? - GT
Hi @Greta26, let me see if I can help you out here.
There is no preinstalled app that supports the feature to block specific numbers from calling you i'm sorry to say.
I recommend you to look after a third party app for this feature, just go to Google Play and search for "Block calls" and you should get some recommendations to look for.
Let me know how it went!
