Gur, coz gps in Xperia M working unstable, i'm afraid you can't use normally navigation.
Gur, maybe working after reset or repair, but just for few minutes... later again working bad or stopping working
Finding my place a lot of time, sometime is not finding... Battery draining very very very fast...Need solve these problems, but Sony still don't care... I really seriously thinking about Samsung in future (when 2 years goes end, then warrenty will be end too) and i think i'm not alone which will run from Sony Mobiles to Samsung (or others) Mobiles
Sony you fail again and very very seriously complicated yours situation
No, Gur, i don't think that Xperia M is "cheap device" like you wrote. Yes, this model cost less than Sony's flagmans, but Xperia M is not mean or bad device like i understood, you wanted to say
Problem is not with Sony's devices, Sony making good device and it doesn't matter mid-rage or flagmans are they, problem is with Sony's update politic and opinion about costumers... Sony care much more flagmans costumers than mid-rage smartphone costumers... that's problem. Also problem is with update, Sony doing too much bugs into smartphones software's updates and running then from responsibility. They don't want to release new update and solve all bugs which they made after updates, like we can see... that's problem is...
Try Sony Service Test.
So I should buy a OnePlus or Nokia instead and toss my M2 (which was running perfectly on Kitkat) into trash?
Hello everybody.
Anyway of its a cheap or not cheap device, is there any solution from sony or android to fix the GPS problem??
Thanks
