Hi
I have an M2 dual, which has been encrypted.
When I start the phone it displays in Chinese.
Does anyone know how to change this to English?
I doubt that you will be able to change it, but do contact your local Xperia Care
you need to access the phone
settings > language & input
Hi
The language under settings is already set as English.
Just to clarify when the phone is up and running it is all in English
It is only on the encryption screen that it is in Chinese
