The app maybe called Photo editor or Photos and videos or as a last resort open Settings then Apps and tap the 3 dots menu option icon and tap on App preferences reset but this will also reset your ringtone etc
Settings - Apps and swipe to All then locate and open the app Photos then tap on Clear cache and Clear data then reboot and test
Are you sure you are on "All" tab? It should be there as long as it's installed. Try to find it also in "Downloaded" tab, after you find it scroll down and tap on "Clear defaults"
Glad it's sorted
