It always show "downloading" but never, but with wfi it does in seconds.what might be the problem.
Thank you so much for the answer! Well done!
Thanks. It worked.
You should try reloading your phone and resetting it to factory settings. I did that a couple of times in the best when I was trying to purchase applications with the free google play credits that I accumulated while filling out surveys and other simple actions like liking a page or commenting under a post. Sometimes you should try to contacting the supporting team of the mobile phone provider. There might be a glitch in the 3G networking and not the phone itself.
