Hi there!
So, I updated my phone yesterday with the new Android 5.1.1. However, my phone is not working properly now. The Camera app that comes with the phone is not working, I get this message (Unfortunately, camera has stopped.), other apps that I have had previously installed won’t appear anywhere, but the phone tells me they are installed. Facebook won’t work at all, even though I uninstalled and installed it again twice.
Help please!!!
Hi @MarcoMarin
Be aware that next suggestion will reset all settings of your apps but try go to Settings -> Apps -> tap the 3 dots -> tap on Reset app preferences Then check if those problems persists or have disappeared. I´m at disposal for any question.
