Hi guys can anyone advise me on how I can fix a boot loop. I have a l3 was working fine yesterday morning put it on charge and it continuesly brings up sony logo then flashes and turns straight back off and does this for a few minutes. Repeatedly. I've tried soft and hard reset but doesn't do anything and also tried plugging into computer but again just does the loop. Any advice would be greatful ☺️ thanks in advance
I'm sorry to say that, but it seems to be a hardware issue, one thing you could do is
turn off the device > charge it for an hour or so > run XC on your computer > follow the steps to repair the device but make sure to keep it off > repair it.
Keep in mind that IFF it works (IFF = if and only if), it will wipe out everything on your device and you wont be able to restore it, same is true if the phone stay in bootloop.
Well, as long as the force restart did not work, you have a chance with the Xperia companion. After you download it on your PC , follow the steps in this video: https://www.youtube.com/watch?v=2YQ23k11NFc
If the Xperia companion didn't work, you will need to contact Sony to send your phone for repair.
