i've updated my xperia L phone to 15.3.A.1.14 ..but now camera is automatically turns on in my mobile,
i've done factory reset,but it doesn't work.
with in a minute it turns on min 10 times.it was so irritating...
someone help me to solve this.....
That sounds strange.
You could try this: open camera > press the settings icon > quick launch > off.
Restart your phone and see if the camera still turns on automatically.
It sounds pretty strange. Do you experience the same problem if you start your phone in safe mode?
See the following link on how to boot your phone into safe mode:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
If you experience the same behavior in safe mode I suggest that you clear data for camera under settings > apps > all > camera > clear data. Restart your phone and try again.
first of all thanks for your reply..
i've tried both now.but yet again am facing same problem..
i dono wat to do
help me to solve this problem.i was frustrated by this
How to do that.can i do that in mobile itself or in pc
i've done software repair.but there is no change.....
is there anyother way to solve this
Disabling auto launch - when I was able to get to the menu - seems to have done the trick for me.
Same problem over here, i just turn off the quick launch
