My Xperia L cpu temperature gets upto 70 degree celcius if i play some games..Is this normal. If not what is a safe cpu teperature?
I purchased Xperia L on 5th Oct 2013... and from Day one it is heating up.
After use of 15mins screen gets so heated up that it is difficult to take call from phone
Suggest what needs to be done...Please help in replacing my mobile handset.
Aayush Grover
Phones will get hot whenever you use them for a extended period of time, or if you are using heavy apps/games etc it will heat up faster. If you think its too hot, take it to a Sony repair center
That is strange as the handset getting hot enough to power off is not normal. Have you spoken with your local Xperia Care team regarding this?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
Do you have a temperature app ? 70C its not a safe temperature to operate your phone
Your handset should be shutting down well before that. Please cease using your handset and contact your local Xperia Care team so that your phone may be assessed by an authorised repair agent.
Yes...i have an app that shows cpu temp..the anfo widget...and it sometimes goes upto 72 degree celcius
Please follow my instructions as per the above as this needs to be looked at sooner rather than latter.
Thanks a lot...will contact xperia care...Just a question...what is a safe temerature range for the cpu?
I don’t have the specifics available to me now but I have never seen one get above about 45-47 degrees.
