okay thanks for your help ..
Wait, can i reset me phone instead of software update?
Anytime.
I bought my Second Xperia M dual sim pone yesterday
and it had battery 46% only and it showed estimated time 1 day some hours
and when i switched on STAMINA mode it showed 3 days 4 hours
when i Charged it to 100% then also with stamina mode on it shows only 3 days 14 hours
even the wifi remains on when the screen is OFF...
I did factory reset, Advanced settings of Wifi (selected NEVER), checked through *#*#7378423#*#*
caliberation code... It says health Good
But still Stamina Mode IS NOT WORKING
IS there ANY HARDWARE PROBLEM
PLZ Suggest
