How do you take a screen shot?
I can't seem to find it
Thank you for any help
Sony exepira L1
Hi @Mb46, welcome to the forum!
There are two ways to take a screenshot. You can press and hold down the power key until a prompt window appears, then tap the "Take screenshot" option. You can also take a screenshot by pressing and holding the power key and volume down key together at the same time.
Hope this helps!
Hope this helps!
