Please can you indicate the higest SAR value reported for Xperia L1 and Xperia XA1 Ultra (ear and body)? Thanks
Hi @Giancarlo_bis,
The highest SAR value for Xperia L1 when tested by Sony for use at the ear is 0.69 W/kg (10g). In the case where the phone is worn on the body, the highest tested SAR value is 1.01 W/kg (10g). For Xperia XA1 Ultra the value is 0.43 W/kg (10g) at the ear and 1.12 W/kg (10g) when worn on the body.
You can read all information about the SAR values via the following links for Xperia L1 and Xperia XA1 Ultra respectively.
Let me know if this answers your question.
Hi @Giancarlo_bis,
Thank you!
Anytime! :smileysmileythumbsup:
Let me know if there is anything else you are wondering about.
