x
vijayarangan
Visitor
safe mode
I'm using my mobile in safe mode now as your suggestion to reduce automatic shutdown. Whether I could install 3rd party application in safe mode.
Why i should prefer safe mode
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
The reason for safe mode is to check if the phone runs OK without loading any third party app's.
If it does you should check which app's you have installed and investigate which one of them that may cause problems.
You can find out more info about safe mode here.
How to boot into safe mode?
2 REPLIES 2
Johan
Master
eaglet1
Visitor
my phone is in safe mode how do I return it to normal use please??
