Hi, I accidentally uninstalled Walkman & would like to reinstall. Is there somewhere i can download it?
ps. I've tried the Update Service but it won't work for me, i get as far as 'connect' but no further
You probably just disabled it,go to settings-apps-all-scroll down to find it.
Ah yes I hadn't noticed the 'all' list. Trouble is tho, it doesn't say 'enable'. 'Force stop' & 'Disable' are greyed out. 'Clear data' is the only thing that's clickable. Is there another way to enable?
All working now. Thanks a lot
Anytime.
