during i taking the pics form cam then the pics is not captured fullscreen .... ... and when the camera is on the screen is getting half of screen is covered by soft key ...
how to hide this soft key ... if not then what happend with my pics why it shouldn't show full image on autorotation screen ...
plz help...
Hi xl49
if possible could you send any images about the screen ??
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
its because of pucture ratio
set it on 16:9 (that nubmer is written beside of mgpixel size)then image comes full screen
but it's not in 8mp
why the camera pics taking long time to take the snap shot or pics from cam
