x
PROBLEM IN DELETING SONGS
SOLVED
MILINDSK80
Visitor
I HAVE DOWNLOADED SONGS ON MY XPERIA L. SOME SONGS ARE DOWNLOADED BUT CAN NOT BE PLAYED IN WALKMAN. WHEN I TRIED TO DELETE THESE SONGS ARE NOT BEING DELETED. PLEASE GIVE SOLUTION.
1 ACCEPTED SOLUTION
Accepted Solutions
discretion1
Contributor
The song files will not be deleted. Only the playlists and other preferences for the walkman app will be deleted. But if you want to be safer, you can easily backup all media files on to PC.
3 REPLIES 3
discretion1
Contributor
First try a reboot and then try to play or delete the songs. Did you try deleting files through a file manager? If doesn't work, try clearing cache of walkman app. Settings--Apps--All--Walkman--Clear cache. Reboot. If it too doesn't work, try clearing data. Settings--Apps--All--Walkman--Clear data. This will delete all your preferences for the app and also the playlists. Reboot. Open the walkman app and wait for some time till it finishes loading all tracks. Now try to play or delete the songs. If nothing works, may be the files that you downloaded were corrupted ones, and you may want to just delete the songs. See if a PC can play the songs. If it too doesn't, then delete them through PC.
MILINDSK80
Visitor
Will this delete all the songs from walkman? because its giving warning " All this app's data will be deleted permanently. This includes all files, settings, accounts, databases, etc."
What does this mean? please explain.
discretion1
Contributor
