Hi,,
I have the following problem with my Xperia L (2105). The screen stays on during Viber calls. It's as if the proximity sensor does not work, but it works just fine during regular calls and facebook calls. The only way to turn the screen off is with the power button. Is there a know fix for this issue?.
Thank You...
