either contact a Sony moderator or contact your local Sony Xperia care (phone, live chat, email) or check the XDA forum
just like your previous post
http://talk.sonymobile.com/t5/Xperia-L/bootloader-unlock-allowed-BLANK/m-p/676977#M12001
same service menu
Use the search bar, and you will find the answer
it seems that you had either flashed your phone or unlocked your bootloader; if you flashed a different firmware/ftf file, you will only be able to find the region of the latest firmware not the original firmware
