- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I want to hard reset my Xperia L but pusing the volume up plus power simultaneously does not seem to work. Any ideas?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
No, its not possible to push these keys to reboot/power off on phones with an external battery.
I suggest that you take off the back cover and remove the battery for a few seconds. Put it back and power on again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi need to reset factory settings forgot my lock screen pattern, what do I do???
