I forgot my mobile's unlock pattern.I do not have my xperia or find my device account.I just want to Factory Reset My Sony xperia L ,I dont care if all the informations are deleted.Please help me to Factory Reset my mobile.
I'd suggest that you perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory.
Follow the steps given in blue links, and keep us updated.
Is there any option other than this ?
Like pressing and holding the buttons.
I have installed version 1.2.8.0 in my computer.I followed the steps until I went to the page where it showed 5 instructions , but when I switched off the mobile while pressing the volume down button and connected it to the computer , after that nothing happened.Please help me to repair it.
Hi @Paranth,
I'm sorry to hear this. As @Quester pointed out, to reset your device and remove any screenlock from your device you need to perform a software repair using Xperia Companion.
When you plug your device in what happens, does the device power on? I recommend that you try a different USB-port on your computer as well as a different cable and computer if possible.
Keep us posted on how it goes.
Please help
Can i press buttons to unlock
