hello. i bought a new xperia L but why i can't turn on the flash when i touch into the flash icon in camera apps??
Hello brother Flash will not work when HDR mode is ON. That's not a problem .Turn off HDR mode then you can access the flash setting.OK
Can u post a pic?
yes. this is the picture. i'm use xperia L,android 4.1.2 build number 150.0.A.1.31
you look at the flash icon. it does't shine like the other icon. when i touch to on the flash,it doesn't respond. what the problem??
Try to reset your Camera Settings. Goto Settings > Apps > Camera > Clear Cache and Clear Data. If it doesn't work try to factory rest your phone.
thanks.. i'm newly in using the android system. thanks..
Hey friend my camera flash is not working neither in camera nor in other apps which uses flash
Any updates on this? Im having the same problem Xperia C. It started when I installed a flashlight app Super-Bright LED Flashlight
you have to turn off the HDR.
