Sorry for the long subject,but I couldn't really explain it shortly.My problem is that my phone corrupts photos and videos after taking them via the camera,I recorded a 30min video of me and my friends playing soccer/football and when I wanted to play it back,the video had green lines in it or didn't even play,claiming that the video had an invalid URL...same is with files downloaded from my pc,they work on my laptop but when I transfer them via MediaGo they either can't be played,are corrupted or unreadable.The SD card itself isn't corrupted because I plugged it in via an adapter and all the files I transferred(manually,not through MediaGo)were fine and the phone read them ok,but I don't want to have to turn off the phone and eject the SD card every time I want to transfer a file 😕 .My card is a class 4 Kingston 8GB SDHC.I didn't have these problems with my X8,why does having a better phone mean more problems ,please help me on this because I've already tried formatting the card 3 times with no luck,I also factory resetted it,same result.Oh and some of the videos I have on it play,but they stop at random(different every time)times saying invalid URL or the video can't be played.
No problem,it is important to work.
I just wanted to inform every1 that I just got the latest update and it did fix my problem,no more corruption whatsoever,I'm so happy
Great.
Hello.
I've been having the same problems with my phone. But even with the latest update it didin't fix it.
I read all of your posts, and tried almost everything.
Can you please tell me what kind of SD card you are using, mine is a Kingston 8GB SDHC.
Oh,sorry I forgot to mention ;D ,the update soved my problem as in it allowed me to do a low level format that worked this time...it now works like new ,if you haven't tried doing a Low Level format I can tell u which program I used for it and talk u through it.
Edit:BTW my card is also a Kingston 8GB SDHC
Dan,I have told you about low level format,I have recommended it two times before and it worked.
Yes I know that You recommended it to me,but be4 the update it didn't help(I did it twice,and a normal format twice as well),when I tried it for the last time after the update was complete,it gave me the result I was hoping for ,but the important thing is that it works now,thank You very much for all your help
Glad to help,do come again when you want to share something or just see some news(hopefully not with problems).
I sure will,thanks again
