Do you mean that you hear the tones when you are using a headset but not via the ear speaker? Do you hear the counterpart while using the ear speaker? But as uliwooly said, a brand new SIM-card would be recommended.
It seems that you had other network issues, get a brand new SIM card, if that doesn't help/work then take it to a Sony repair center
Just comes up: unfortunately contacts has stopped
