http://www.sonymobile.com/global-en/products/phones/xperia-l/specifications/#tabs
Memory
** Memory comprises of approximate 1.2 GB firmware and 5.8 GB “Internal storage” for downloaded applications, music, pictures and films, and some application data.
As another user has previously posted
Xperia L in factory condition (without third party apps installed) has around 5,5 GB of free space divided between phone memory (1.5 GB) and internal storage (4 GB).
The remaining memory isn't user accessible and is occupied by OS and recovery partition.
You can use an external microSD card to increase available space but here you can't install apps but only put your personal files.
