I can not use the phone to connect to nearby devices. Sony only allows google 8.0 on its own devices. What is this
I had an email from AOL saying I must update my device which is Xperia L1 to 5.2 to be able to use the AOL App, have tried, no luck, I'm not very technically minded
If you are trying to update the app just open the PlayStore > type AOL > update the app
your phone is running on Android 7.0 right?
settings > system > about phone > android version
Yes it is 7.0, I did try updating through AOL App ,followed all steps, clicked the box for auto updates but still can't log on, I get an error page with no error number each time I try
google android soon specifies the feature can be used in 8.0 oreo version settings. I do not think this phone will be upgraded. The features mentioned in the software are also limited because the phone is cheap. I do not understand the brands that put the consumer in such trouble. why do you drive into a useless phone market because of competition with other brands? This phone works well except programs such as facebook, twitter, etc. Even mobile internet sharing is problematic. You are pairing two devices with bluetooth. I do not see each other in a short time.
Please upgrade your software and make all kinds of use convenient.
I do not have to do all the devices in the house sony.
even with a computer with windows 10 installed. I should be able to communicate between my devices. He's doing samsung, he's number one on the market.
For the first time in my life after Samsung phone, I got sony. If you believe that this phone has features, take one and test it.
That's what I would like to know
