I can not use the phone to connect to nearby devices. Sony only allows google 8.0 on its own devices. What is this
Can you please give a more detailed description of your issue?
What connection mode you are trying (Bluetooth, WiFi-direct, etc)?
What other devices are your trying to connect to?
The device shares features with the nearby devices, but such a feature is limited. For example, a computer with windows 10 is not even a la. In this case, I will make all the devices except the phone sony. Google also says that in every release this feature will be available in the next version. In this case we will use a third software.
Do I have to do all the devices sony?
When will ıt update Android 8.0?
If I understood well, you're talking about the "Nearby" functionality introduced by Google. This feature does not require that all the devices are Sony-made or with Android 8.0 installed. For example, you can use the Nearby feature to transfer the content and accounts of your old android device (with NFC) to a new one.
Now again, what are the connection type and devices involved in your question?
And for the update question: Xperia L1 was not among the official list of devices announced by Sony that will receive the Oreo update. Check more info here.
I'm sorry I can't read Turkish and I'll not be able to translate the contents of a screenshot. It would be appreciated if you give a brief translation of the part you want to point out.
sony l1 I have a communication problem. Internet sharing is as slow as it is difficult. Google 8.0 does not allow gold. sony gives it to their own devices. What are we going to do, throw away the bunch of appliances in our house and buy a sony device? This device can only be used with facebook, messenger
and so on ...... we do not need this device if we are going to use it for applications or photography. I received this device for the first time because of its communication features ads. But I could not believe what I hoped. You can not market the brand like this and it does not seem to be resolved. If you call it a cheap device, try a samsung with the same features. I wish I had bought samsung. I hope that this will be over soon, otherwise I will have to buy a new device.
Can't access AOL login, need to update,
how do I update to 5.2 or higher, have tried updateding through AOL App with no luck
