Anyone else have this problem?
Hi there
Are you using wifi or a LAN cable to connect to your router? If wifi, can you please connect a cable and change the network settings to reflect this - test and see how it goes.
Changed settings and connected via LAN cable.
Same problem as before some Apps work, but I-player and YouTube still buffering after selecting.
It might be worth trying using Google's DNS settings, I used to have this problem myself occasionally before changing them. See my reply in this post for further information:
