Hi!
I can't find this information anywhere and it's driving me nuts.
I have a MacBook and I have formated my USB-disk to ExFat. I can see my USB-disk in the home menu but it says "Unknown USB". On my disk there is a .MKV file that I want to play. Is ExFat not supported or is the problem that the .MKV file is not supported?
Is there a list of which files and formats I can and should use with BDV-EF1100?
Is there anyone else with only a MacBook that has a neat tip on how to make it as easy as possible to play my media through a USB-disk?
Hi there
Sorry, should have said in my original post (watching football at the same time !!) In the specs it says FAT32 and NTFS is supported.
No worries! Thank you for the help. I will try with MS-DOS (Fat) when I come home. Works on all my other players and units so it would be perfect!
Thanks a ton for the help.
No probs. Good luck with everything.
