Can i surf the webb with SMP-N100?If so-how?
regards from sweden
Hi there
No you cannot - The N100 does not have an inbuilt browser. The SMP-N200 does though.
Ok thanks.Is it possible to stream a movie from a computer on the same network?
Thank you very much,i`ll try if i can get it to work.
regards jonny
