Hi I have a blu ray/cinema sound unit in our garden room. I have gone in there today and turned it on but it turns itself off. It comes on and says "welcome" then it clicks off. If I leave it for about ten minutes it comes on but does the same. Any ideas whats wrong before I have it repaired ? can the area its in be too cold ???
Hi there
Depending on the situation, it "could" be a condensation build up on the electronic circuit boards that are cutting out. Try setting it up in the lounge room or somewhere, leave it for a day for it to adjust to room temperature etc, and then test
