I recently got myself the NSZ-GS7 which I have connected between my Sky+ HD box and my tv. Before the Google TV installation I would turn on my tv then hit the sky power on and the tv would "wake" onto the correct HDMI port. Now I have to manually select the right HDMI port with the tv remote. This is really annoying.
Is there a way to set up the NSZ-GS7 so that the old behaviour returns?
Thank you
What tv do you have?, also have you tried different hdmi ports
It's a panasonic Viera. Not sure of the model, but it's about 3 or 4 years old. I haven't tried different ports. It's always been able to autoselect the HDMI port (in this instance 1) just by turning on the Sky box.
Maybe check model and manual to see if there is a setting that needs altering.Does the tv find the NSZ correctly when it's directly connected to the tv. When the tv is switched off is the correct hdmi input selected for this device ?
