I have recently purchased a BDP-S370 Blu ray player and want to use a usb wireless lan connection. does anybody know whether i have to use the sony UWA-BR100 or can i use any wireless adaptor.
Yes it needs to be the UWA-BR100 or a set of homeplugs. The device doesn't have the driver database that a PC does thus it needs to be a particular dongle.
Thanks
