- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
UHBP X800/HTST5000
The X 800 spec states that it decodes both Dolby Atmos and DTS -X based surround sound from disc, and outputs this on the HDMI 2.0 audio port as 7.1 . The HTST 5000 soundbar spec states that it receives Dolby Atmos and Dolby HD on HDMI,but not DTS.
So in order to play UHD discs with only a DTS-X soundtrack, it will be necessary for the X800 to convert DTS -X 7.1 into Dolby Atmos 7.1 prior to transmission to thg soundbar.Does it do this ?
The alternative is the Pioneer Elite or Oknyo Dual object based audio format soundbars,but I would like a single source supplier for my whole system. (along with the A1 OLED in the UK ! ! )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Even though the UHP-X800 can decode DTS:X, unless the soundbar can output DTS:X then it wont play. In the manual for the UHP-X800 you can output audio via bitstream, but it only mentions Dolby/DTS, with no mention of Dobly Atmos or DTS:X - so I am unsure if this would/could work.
According to this link below, it states that DTS:X will be enabled with a future Firmware update, however I can find no other instances for this. Many articles link the HT-ST5000 and the STR-DN1080 together of which the STR-DN1080 will get a DTS:X upgrade via firmware - so you might want to contact Sony directly and enquire about this:
http://www.avsforum.com/sony-ht-sr5000-dolby-atmos-soundbar-demo-at-ces-2017/
If DTS:X is an absolute must, I would recommend the STR-DN1080 over the soundbar. Although I have heard Atmos played via the HT-ST5000 and it is really good and volume can go quite high too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, great link to CIS 2017 HTST5000 demonstration, with far more informatrion on DTS capability than is avaliable on the Sony soundbar site.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, great link to CIS 2017 Sony sound bar demonstration with far more information on DTS capability than is on the Sony site.
The bit I don't get is why wait to implement DTS X by firmware,when the sound bar isn't released yet, and so it could be upgraded with the DTS X Codec now.
Of the 6 recognised UHD Bluray demonstrator disks ,which I have just bought as a package, 2 of them have only DTS X in the English language soundtrack.
I bet Dolby Atmos is awesome though HTST5000.and that the UHBP X800 picture would be awesome though the A1 OLED,but I'm still waiting to purchase that system in the UK, so my 10 year old Pixel Plus processed CRT and Dolby Digital 5.1 system still rules.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
my soundbar came ore loaded with the software upgrades in DEC 2019.
