I've done a software update for the UBP-x800. It lost video after the update and hasn't worked properly with my system since. It is connected to an Anthem MRX-720 (then to Sony projector) and has worked fine until the update. Now, it continually loses HDMI sync so that audio only plays for about a second, then goes off for about 5. Video doesn't stay long enough to be able to see anything. The player does connect to an monitor I've got (not 4k) so I have checked the firmware and it is the latest version. I've tried different HDMI inputs on the Anthem, but no difference. The Anthem continually flashes 4K/no-signal, and PCM/no-signal. I can't see a way to take the firmware back a rev, but wish I could as previous one was fine. I've also disconnected all other inputs on the Anthem, with no change
Has anyone else experienced similar with latest firmware (M36.R.0238)
Thanks
Hi there,
Hopefully one of our members will be able to help with this.
Welcome to the community.
Best wishes,
M
I'm having same problems since last update. Already opened a ticket
I hope they'll get this fixed soon..
I feel like a beta testing user.
