On the specs it says the player supports dsd playback, but it does not recognise any dsd files from my NAS. Is there any way to get itto recognise the files? I tried from a usb drive and they work, why not over the network?
Thanks
My son did this job for me...something like right click on network symbol from task bar and into Open Network & Internet Settings you should enable the Media streaming rights for Sony.
Any news?
Under the Sale of Goods act you can return item for full refund if misadvertised or doesn't do something it says. I returned mine to Richer Sounds as they accepted miss sold for refund/change of model.
There is a time limit I believe, but still worth trying.
I receive this toy. It can play everthing from and to Foobar server, but only as PCM. No native DSD, just like any other cheep chinese more sofisticated media players.
It can stream or play 176.4K/16bit 6 channels ( as 64 DSD can be divided ), but only a few seconds..a few samples of pac, pac, pac and then again and again ...16.9Mbit/s is the maximum bitrate for this superb player. When the stream reach 17Mbit/s then the pac, rap, pac come into place.
Maybe the software implementation is made by a 98 year old engineer, as the disc part is like the most future proof.
Heavy, well build, but without any logic.
Finally! Yay, just goes to prove if you stick at it, one day you will find the answer.
I had tried various dlna servers to no avail, but then I tried Serviio and it worked. The player now not only plays all the usual formats, mps, flac etc, but dsd64 and amazingly dsd128 both play now.
So if you want to fully use the potential of this very nice player to play hi-res audio, install Stremiio and your problesm are solved.
Hello mrstester,
Could you please tell me where you have your files stored and where you installed your server. I installed Serviio on my PC and it couldn't get acces to my NAS with all the music files. Thanks, Eddy
So what are you using?
You mention 2 different software items that are close to the same but not?????
