As any one been able to connect this DVD player to a Sky sound box if so can you let me know how?
Thanks K
Hi there,
Welcome to the community.
We will look into this and get back to you as soon as we can.
Meanwhile, another member may be able to offer some advice.
Best wishes,
Ed
Hi Reactarail,
I believe you just need a HDMI cable. I've just had a look into the manual and I found a connection guide on page 12, you can access it through this link: http://bit.ly/2x8Nzsz.
Cheers,
The_Black_Rose
Hi reactarail,
I don't think this player can be connected via optical. It doesn't have an audio in/out jack.
Cheers,
The_Black_Rose
Hi Reactarail,
I don't think so. Usually manufacturers can't guarantee that the adaptors would work.
Cheers,
The_Black_Rose
