I have replaced the lamp in a projection tv.When i turn it back on it goes into standby.
Please help,as i have a 2year old driving me batty-as we have no tv!!!!!!!
Topic moved into correct folder.
Nico
Hi niamh2008,
welcome to Questions & Answerers..:smileyhappy:
Is there a possiblitity that is was not more than just a lamp needing replacement that was causing a problem initially..
Perhaps it may be worth contacting an authorised repairer for advice..:smileyconfused:
thanks all for your replies,will have to bite the bullet and bring to repair shop x
You're welcome, hope all goes well with the repair..
