My DVD Recorder RDR-HXD860 will not record in HDD. Fault shown on screen is "The disc is dirty" (no disc inserted as recording is to hard drive)
Can anyone help?
sounds pretty much like you need to "wipe" your hard drive within the recorder, if you have been using it a lot with bits and pieces of recorded programs it may need a full wipe, just erase everything thats on it and see if that clears the problem.
Thanks. I have tried a full wipe of the hard drive without success. The problem is still the same.
rodandalex,
thats unfortunate, have you tried opening the disc tray and closing it?, i know it sounds silly but try it, failing that try unplugging from the mains for a couple of minutes see if that does anything.
I have got excactly the same problem on my RDR HX820... Have you found a solution???
