Hi.. I have a BDP S580 and Windows 8. I have network plugs so internet travels in the house wiring. I cannot seem to be able to play content from my PC via the dvd player. I have them all hooked up to the router but cant fathom it out. Anyone out ther can help..THx
Couple of things to test out
Hope this helps
Hope this helps
Hi..Yes it worked a treat. Thank you v much..
