STR-DN1070, firmware M35.R.2135 and new "Chromecast built-in" should allow playback from Standby
profile.country.PL.title
MarekSuski77
Explorer
With https://www.sony.co.uk/electronics/support/audio-components-receivers-amplifiers/str-dn1070/download... I should be allowed to wake-up amplituner by just selecting it from Chromecast enabled app e.g. Tuner-In - unfortunnetly it does not work. My phone, iPhone SE with latest iOS, is connected to same network (phone by wireless and amplituner via wire) and using Sony's "Video & TV SideView" I can wake it up but not with "Chromecast" as advertised in firmware description.
Does any one know what I should check/change to make it work?
Marek
5 REPLIES 5
profile.country.GB.title
cass_n
Community Team
Hi @MarekSuski77,
I think this is happening because the receiver isn’t connected via WiFi. To my knowledge, Chromecast works only via WiFi connection.
Cheers,
Cass
MarekSuski77
Explorer
Hi Cass,
I have switched to wireless and still cannot wake-up the amplituner from my smartphone. Thx for the hint.
BR,
Marek
cass_n
Community Team
Hmm.  It might be worth getting in touch with Support so they can assist you with this: http://services.sony.co.uk/supportmvc/en/Contact/Email
profile.country.SE.title
mrcodec
Explorer
Hi, If you live in EU you will experience this problem because Sony choose to deactivate this feature...
"Perform the settings to use Chromecast built-in on the receiver by following the on-screen instructions.
Once the settings are configured, [Network Standby] is set to [On] automatically, and you can quickly start up the receiver from standby mode to play music (for USA, Canadian and Asia-Pacific models only)."
https://helpguide.sony.net/
MarekSuski77
Explorer
To solve this problem should I use firmware for US or maybe select different region in amplituner?
