After performing the auto speaker calibration and selecting a setting ("Full Flat" for example), this setting is not stored.
When I switch the receiver off and on again, the speaker calibration setting is ignored, although it still says "Full Flat" in the menu. The sound is as if it was set to "Off".
I need to manually set the setting to "Off" and to "Full flat" to hear the correct speaker calibration.
Thanks for your help!
Phil
Yes, I am 100% sure it is being applied. I shutdown the AVR, powered it on again and played a movie and it was the same as I left it. I then changed from Full Flat calibrated to "Off" and it sounds bad compared to the saved settings.
Good luck with the repaired unit.
This is so weird and honestly, I can feel your pain.
I tested my unit thoroughly because I bought it from Amazon UK internationally to Egypt, so any problem with it would put me in a worse situation.
I think your best bet at this moment is to take it to Sony store, show them the issue, get a replacement unit and test it there.
Even if it took hours, it is still better than having to live with such an issue or waste another month.
By the way, my unit model is: STRDN1080.CEK and was bought on June 9, 2018.
It has M41.R.0442.
