I am looking for 2.1 speakers with a clean design without having to spend a fortune, do you have any tips?
__________________
Hi there
Unfortunately you didnt specify whether you want Bookshelf style speakers or a Soundbar.
Bookshelf style
I have not actually seen a 2.1 bookshelf style setup. However there are 2.0 sets, and then you add a sub. However they are not in the "normal" affordability range. See HERE for the range - however some do not have prices.
Soundbars
Sony do a range of soundbars for a range of prices. Have a look at the HT-CT260H model - or browse the range : HERE
Hope that helps
Hi there
Bookshelf style
Soundbars
Hope that helps
