If that's not working for whatever reason, there's nothing wrong with plugging the box straight into your TV via HDMI, then connecting up to your Soundbase via optical. Hopefully that should work just fine.
Let me know how you get on.
Mick
Mick, I know it’s a long time ago since I raised this issue! I did as you suggested and was able to get around the problem, thanks. Since then I have bought a 4K UHD TV and have reverted back to the original HDMI I/P on the Sound base and removed the optical link. All is now OK.
Mick
