Soundbar advice
SOLVED
profile.country.GB.title
Adeyfred
Explorer
Soundbar advice
Hi all, advice/help please, which soundbar would be comparable with my TV? Model KD55XF9005
One to fit in-between the TV legs would be preferable
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.DE.title
IamNic
Expert
Hello @Adeyfred,
the Sony HT-X9000F soundbar is designed to fit between your TVs legs.
It is the TV features on the product site: https://www.sony.com/electronics/sound-bars/ht-x9000f
Therefore I am confident to say, that it is fully compatible to your TV. :thumbsup:
- Nic
4 REPLIES 4
IamNic
Expert
Hello @Adeyfred,
- Nic
Adeyfred
Explorer
Thank you sir
Priced this one up today 👍
Adeyfred
Explorer
Thank you IamNic!
IamNic
Expert
Hi @Adeyfred,
you're very welcome :smiley:
- Nic
