thanks alot for responding.
I figured it out...
I used the hdmi cable going between one of my other devices and used that for the ARC connections instead.
Now, sound is coming out from the TV when I am in TV mode.
Rather annoyingly the cable behind my wall must be an older specification cable which cannot handle ARC.
From reading this afternoon - looks like I need a hdmi 1.4 spec cable instead which can carry that signal.
thanks again.
Be sure you have activated bravia-sync on both tv and soundbar (and other device too at least for the bdp) so you don't have to deal with the switching of the soundbar channel... then check if audio is set to the external speaker (via the options button) rather than in internal.
I figured it out...
thanks again.
Great job! It's always nice to hear a success story.
Please click the 'Accepted Solution' button at the bottom of your last post, it will help others looking for a solution to this problem.
Dr.Slinky McVelvet - Inventor of the word 'Mellifluous' - 30.12.14
