I'm having a problem with this player when using the 'Stop' button on the remote
Instead of stopping the disc and returning it to the beginning, it seems to be acting like the 'Pause' button by simply stopping the disc at the point the button was pressed
By pressing 'Play' the disc resumes playback from the point I pressed 'Stop'
So if I want to start the disc from the beginning I have to repeatedly press the 'Return' button and move backwards through the chapters or open and then close the tray again
Surely this is not what Sony intended the user to do ?
Any advice ?
Hi eltaylo65,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
I found that your player is a professional grade item. I'd get in touch with Sony Professional if I were you:
https://pro.sony/en_GB/support-services/support-contact-us
Win_88
